Spring length front axle
I am in the process of swapping my D250 to 4wd and I am looking to use a set of leaf springs out of the junkyard until I can afford a set of atlas springs. I know I need a 2.5 inch wide spring but what is the length of the spring should I be looking for in my local pick a part to hold me over until then. I have fab skills and a great welder. I can build the mounts and shackles but I don't wanna buy springs that are too long or too short. Any help would be greatly appreciated. Sorry if this has been gone over. I used the search and didn't see what I was looking for.
Btw my truck is a 91.5 D250 and I bought a Dana 60 out of a 91 dodge W250 |
Here ya go.
Leaf Springs for 1972 - 1993 Dodge D300, D400 |
Wow this site never disappoints. Should I get the 1750 lb spring or the 1900 lb for under the heavy cummins. I don't wanna buy a set that will sag right away. Thanks again!
my stock ones have 6 leaves so I would go with the 1900#
I appreciate all your help Mark. While I'm able to pick your brain. Any idea where I could pick put a set of 4 inch lift blocks and u bolts for the rear axle to level her out?? Thanks for all the help.
Brock |
Originally Posted by TrkEnvy
(Post 3313106)
Brock |
I purchase my ubolts from a local truck shop. They make them on site and are cheaper after shipping costs. Might want to check around.
Originally Posted by twostep
(Post 3313164)
Some people do the rear shackle flip to gain a few inches instead of blocks. Depending how you plan to use the truck, that might be worth looking into.
Originally Posted by 1992gen1_fan
(Post 3313204)
Originally Posted by mknittle
(Post 3313092)
Here ya go.
Originally Posted by KRB
(Post 3313301)
Dang, those prices look cheap. Have you tried them?
(Post 3313301)
