Speed Sensor Question
Old Jan 30, 2008 | 10:24 PM
gcliburn's Avatar
My speedometer jumps some, especially when doing 70 or more for extended periods. I have replaced it with one from a discount type parts store in the last year or so. I think it is the speed sensor. Would you guys get another 35 dollar one at the same store or price one at dodge?
Old Jan 31, 2008 | 10:44 AM
Ezra's Avatar
I would go with the Dodge OEM part, it's like 68 dollars but you get what you pay for.Anyway thats what I did.Good luck.
Old Jan 31, 2008 | 11:14 AM
Chrisreyn's Avatar
They dont go out THAT often... I would check your wiring harness for brittleness and chafing, you may have a short in it, and check the ground well. Make sure your connections are clean and tight, especially if you have any oil leaks or such, they can get gunked up pretty easily..
I would also look at the Drive Pinion gear for wear, if it is only happening at speed...
Old Jan 31, 2008 | 01:32 PM
93beater's Avatar
got mine from checkers its good so fAR
sjester
May 10, 2007 05:03 PM
sjester
Nov 24, 2004 07:28 AM
badmrb
Oct 21, 2004 09:26 AM
buckman361
Oct 19, 2004 08:20 AM
