Should have adjusted Valves a long time ago!
Old Aug 20, 2010 | 06:29 PM
Originally Posted by Onemoparnut
It sucks you do a mod you want and then it usually creates another mod you need lol...
That is a great line right there. 100% truth.
Crank up the pump.......
Need a clutch......
Old Aug 20, 2010 | 06:58 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
injectors=turbo and lift pump
turbo=head studs
govenor springs=valve springs
i could keep going
Old Aug 20, 2010 | 07:04 PM
dieselJon's Avatar
turbo=head studs
i could keep going
All of the above, new rods.
Old Aug 20, 2010 | 07:51 PM
MoPowa's Avatar
Bigger tires=New leaf springs
Bigger tires with above upgrades=New TC
Old Aug 20, 2010 | 08:50 PM
IRoss's Avatar
Its all true,for sure but imho valve clearances are pretty much routine maintenace in everything I own almost, I'd say that I check my valves more than my oil sometimes...one of the best ways to stay on your top end!
also:
new car hauler = new water pump & rad
Old Aug 21, 2010 | 08:19 PM
NE frmhnd's Avatar
I should check mine but it's pretty quiet and starts good. I know the dozer has a 4BT and it's pretty bad. When I get home this winter I think I am going to lash them for dad before I leave again. It ticks pretty bad.
Old Aug 21, 2010 | 08:59 PM
if the 4bt had a piston lift pump in it, that will tick pretty good. mine does anyway.
Old Aug 21, 2010 | 10:24 PM
ice man son's Avatar
I have a 93 dodge, I was planning to get my valves adjusted, but with all of the other modifications I am going to( turbo, pump turned up, timing bump) do, I was needing to know if it would just be a better choice to get stronger springs. some questions I have- WHAT IS THE SAFE LINE TO DRAW ON THE BOOST PRESSURES THE SPRINGS CAN TAKE?
I am pushing over 30 lbs
Old Aug 21, 2010 | 10:26 PM
30 lbs with these modifications( turbo, pump turned up, timing bump)
Old Aug 21, 2010 | 10:28 PM
i wouldnt worry about boost. unless youre running an exhaust break or plan on running over 3500 rpm a lot thats when you think about springs. i just got done changing my valve springs about an hour ago. it was quite easy. you do need a few tools like a 1/2" torque wrench and a valve spring compressor.
Old Aug 21, 2010 | 10:31 PM
MoPowa's Avatar
From what I understand heavier springs are only needed if you plan on using an exhaust brake or revving the engine to 4000+rpm. Though, if you have the money and time it wouldn't hurt to do, and you have confidence later on if you plan on really pushing .
Old Aug 21, 2010 | 10:32 PM
MoPowa's Avatar
The second time this week someone beat me to the answer
Old Aug 21, 2010 | 10:38 PM
Yeah my stock valve springs seemed to be ok, i run my truck up near 3600-3700 rpm. I dont know how long they would last up there though. Its pushing it.
Oh yeah- I did all 12 springs for about 200 bucks and thats with the Cummins brand springs, a spring compressor and a magnet!
Old Aug 22, 2010 | 12:35 AM
NE frmhnd's Avatar
A quart of Lucas in the oil quiets it some. The machine has about 10,000 hours on it. We've changed injector o-rings, manifold gaskets, and motor mounts in the last 15 years. I can't remember when we got it but shortly after that the cam broke, so that's the last time it was really opened up.
Old Aug 22, 2010 | 01:03 AM
GLHS's Avatar
Valves float due to a combination of boost and rpm.
Mine started to float after repeated runs down the track running 38 psi and 3500-3700 rpm IIRC.
I changed all 12 to 60# and have run to 4100 rpm pushing 45 psi or so with no problems.
