RWAL Test Connector Location ?
Old Sep 23, 2019 | 09:25 AM
Anyone know where the RWAL Test connector is located in our rides? I'll assume it's under the dash somewhere.
I'd like to see if I can generate codes to see what's going on with the dodge lights being on for RWAL. Page 4 has you ground it out, but it doesn't tell you where on the truck it's located.
Thanks.
Old Sep 23, 2019 | 09:38 AM
cougar's Avatar
It is a single wire taped to the harness to the left of the RWAL control box.
Old Sep 25, 2019 | 01:29 PM
Black square connector taped near,the main harness in front of the glove box,mount bar.
I'm getting a code #9.
Speed sensor wiring resistance (usually high)
Broken, bare wire? It rubbed through one of the sensor wires
Very easy to test. Pull the ground wire off the glove box light base, and briefly touch the tab inside the connector. The amber lamp will then flash, if you have a code.
Thanks!
Old Sep 25, 2019 | 02:54 PM
Codes are gone. Now all I have to do is test drive it.
Amazing, what a broken wire can do, eh?
Nick & Kels 08
Apr 18, 2011 09:16 AM
dieselfuelonly
NCDTR #18
100
Nov 14, 2007 04:15 PM
LanceD
Off Road / 4x4
Feb 6, 2007 09:34 PM
hilclmr
Jun 5, 2005 12:45 PM
