Rockstar wheels
Old Jan 11, 2012 | 05:09 PM
olgrey93's Avatar
Rockstar wheels
I saw a 93 d350 or w350. Couldn really tell but what would I have to do to fit those rockstar wheels on my 93d350?
Old Jan 11, 2012 | 05:47 PM
7horn's Avatar
Order them in the right size.
Old Jan 12, 2012 | 09:41 AM
texsasdiesel's Avatar
the aftermarket rims usually fit over the 5/8ths studs that are found on our trucks, the problem comes in when you put them on the back, as we have "coined" rims, you can either take a die grinder to cut some grooves for the coined portion of the rear wheel to fit into the aftermarket rear dually wheels, or you can grind off the "coined" portion on the steel rim.
I'm sure some others will chime in w/ some more helpful info, but that's what i've found out about putting aftermarket rims on these 350 trucks.
On my own project i ordered some 9/16ths studs to replace the 5/8ths as they are more readily found and offer more options for wheels and cheaper lug nuts. there's not an exact "drop in" or "replacment" stud that I've found, so i found some that are close and will drill out for a press fit when i get home.
James
initiald843
Jul 6, 2009 10:25 PM
kylineman
Jan 31, 2009 06:20 PM
Cold Diesel
22
Jul 18, 2007 09:44 AM
Jordan5687
0
Jul 6, 2007 08:52 PM
FortMacSummit
Jan 29, 2007 02:07 PM
