Replaced cycling switch. What temp do you have at the vent?
Old Aug 14, 2018 | 06:06 PM
  #31
maybe368's Avatar
Originally Posted by Brian Green
The system was installed once I moved from SOCAL and needed AC, hasn't been under a tree since the install! But I have put in a boat access panel on the front of the suitcase and it's still clean and clear. I put new foam and duct taped the seams on the vents when it went back in the cab... I've got a finicky vacuum actuator that I have to give some love to though. I call it my weekend truck, drive it all week, and work on it all weekend...
Just for your information, if there is a pine tree within 3 blocks of the truck, you will find pine needles in it, they are evil...Mark
Old Aug 14, 2018 | 08:45 PM
  #32
rlyons's Avatar
Where did you get the new cycling switch, I think mine is failing.
Old Aug 14, 2018 | 08:47 PM
  #33
mhuppertz's Avatar
Originally Posted by maybe368
I just have 1 thing to say, HUH?...Mark
In other words, r-152a will blow about 10 degrees cooler than 134a, roughly equivalent to r12.
Old Aug 15, 2018 | 11:13 AM
  #34
Brian Green's Avatar
pulled the cycling switch off a junkyard pick in pull... that may be one you have to mod to work a "like type" model that achieves the same effect, the line fitting should be standard it's just if it's a 2 or 3 prong dongle on the end, I can't remember off the top of my head.
Old Aug 15, 2018 | 01:38 PM
  #35
nothingbutdarts's Avatar
BTW - R-152a or 1,1 Difluoroethane is "Air Duster" commonly sold in the electronics section of any box store... Cost was $12 for 3 10oz cans.
Man, I went into a Staples store a few weeks ago and bought 3 cans of compressed air, $22.00 for the three and they card you to buy it!!!!
Old Aug 15, 2018 | 02:03 PM
  #36
Chevjerico's Avatar
I went to Pick-N-Pull. I did find a new one for $280, too much for me.
Old Aug 15, 2018 | 03:14 PM
  #37
maybe368's Avatar
It's been 5 years, butt shipped these people may still have new ones for less than 50 dollars shipped:
Thanks, Bob Schaetz @ East Texas Auto Air & Glass
1019 West Marshall Ave.,
Longview, Texas 75604
ph 903-753-0089
fax 903-753-0076
cel 903-720-1922
Part #E56-1101-016 It was 34 bucks plus 9 bucks shipping to Phoenix
He said that he had a few of them at the time...Mark
Old Aug 15, 2018 | 03:15 PM
  #38
maybe368's Avatar
It's been 5 years, but these people may still have new ones for less than 50 dollars shipped:
ph 903-753-0089
fax 903-753-0076
cel 903-720-1922
Old Aug 15, 2018 | 03:38 PM
  #39
Chevjerico's Avatar
ph 903-753-0089
fax 903-753-0076
cel 903-720-1922
Thanks for the info, but same guy. He has one left and wants 280😲
Old Aug 15, 2018 | 03:47 PM
  #40
maybe368's Avatar
Thanks for the info, but same guy. He has one left and wants 280��
You've got to be kidding! When I talked to him on the phone, he didn't even know what application they were for. I put a comment on this board, at the time, that guys my want to buy one. I don't know if anyone did. Boy, talk about capitalism at work...Mark
Old Aug 15, 2018 | 03:49 PM
  #41
Chevjerico's Avatar
Yea pretty funny. I'll adapt a four seasons one you can get for 20$ before I do that.
Old Aug 16, 2018 | 08:34 AM
  #42
mknittle's Avatar
Mine was acting up so I moved it in and out out tube in the pressure line. So far it has worked for almost a year now. there is a special heat conducting grease that is used on the probe, Might be worth a try putting new grease on there before buying a new part.
Old Aug 16, 2018 | 08:49 AM
  #43
Chevjerico's Avatar
Have less grease would have the same effect as pulling the probe out. So the compressor would run longer before switching off.
I'm going to check my charge. Like one of the posters mentioned.
Old Aug 17, 2018 | 05:58 AM
  #44
TRENDZ's Avatar
I have an adjustable fin temp switch in mine. It has a probe that slides into the evaporator, and a rotary dial for cut out temp. Its set to cut out at 32degrees to prevent freeze up. I suppose in drier climates I could set the temp lower, but it works great for me here in Wisconsin. Found it in an everco catalog a few years ago. Under $50 if I remember correctly.
Old Aug 17, 2018 | 06:41 AM
  #45
Chevjerico's Avatar
Do you remember the pinout?
