reg cab on a ex cab frame?
Old Sep 28, 2012 | 06:48 PM
90 power ram's Avatar
ok so i have an ex cab and the cab is just shot it is fixabale but i dont have the time or the money. i under stad i would have the back mounts and i would have a gap between the cab and bed i would just put a fule tank or a tool box of some kind i was just wondering if any one has done this swap and has pictures or a link to it.
thanks.
Old Sep 29, 2012 | 12:31 PM
85crewcabbie's Avatar
cab swap - from extended to standard
I went out and measured an extra cab and regular cab chassis (both gas) and it looks like you can easily move the rear mounts forward to accmodate the rear mounts of the standard cab. As you move your extended cab rear mounts forward you approach a dip in the frame rail. My measurements indicate you have enough room to reuse the factory mounts repostioned farther forward. If you moved forward far enough, into the dipped portion of the frame, you could still do this but would have to build a taller bracket to compensate for the dip in the chassis. I went the other way on a 158" Wheel base cab and chassis and their was no difficulty as I was moving away from the frame dip and the long wheel base chassis's length worked to my advantage. Hope this helps.
Audiophile31
Oct 28, 2021 10:19 PM
9MM
Sep 30, 2011 12:38 AM
HOHN
Mar 28, 2008 02:13 AM
gts95
Aug 27, 2007 10:13 AM
ptgarcia
Sep 12, 2006 06:04 PM
