Rear wheel seals-this is ridiculous!
Old Jun 15, 2015 | 09:32 PM
OVERTORQUED's Avatar
10 Year Member
Smile
That is definitely a good fix as a temp. Will remember that.
Old Jun 15, 2015 | 10:00 PM
schamran's Avatar
If you still have trouble with leaking seals after you replace them, check your axle breather hose. I cleaned my breather out and haven't had trouble with a wheel seal since.
Old Jun 16, 2015 | 05:56 AM
You know that fitting on the axle cloggs up ever couple of years ?
I've cleaned mine out several times since Bought the truck, and the use of synthetic gear oil did nothing to prevent this from reoccurring
Old Jun 16, 2015 | 10:31 AM
10 Year Member
Boy, was I not prepared for those axle retainer clip/bushing thingies. What fun those were! Thought I was gonna have to be committed or something. They definitely do the job they were intended to do and keep the axle from coming out!
Old Jun 16, 2015 | 11:59 AM
maybe368's Avatar
If you are talking about the little cone shaped thingys, just TAP the edge of the axle flange with a hammer and they come right out. Tap being the important part...Mark
Old Jun 16, 2015 | 09:54 PM
schamran's Avatar
I have no idea what causes it!
Old Jun 16, 2015 | 10:03 PM
Condensation
Old Jun 17, 2015 | 01:18 AM
Jim Lane's Avatar
Temp swings from hot to cold, lower numerical ratios worse as the housing breathes, use a larger diameter line with a filter, some people vent them inside.
Old Jun 17, 2015 | 11:05 AM
10 Year Member
Mine didn't quite come out that easy but will remember that the next axle I do ( hopefully not soon ). Thanks!
Old Jun 17, 2015 | 12:45 PM
j_martin's Avatar
They're collets to keep the axle flange from moving on the studs. Like all collets, they'll bind up after a while. Like all collets, a little vibration in either direction will shake them loose.
Old Jun 17, 2015 | 04:25 PM
Jim Lane's Avatar
I have worked on a lot of heavy equipment throughout my lifetime, some with Rockwell axles, some have had a threaded hole in the flange to drive them out but most you could loosen all of the collets at once with one solid smack in the center of the flange using a sledge hammer, then you could expand the stubborn ones using a small screwdriver.
We also had to pull the axles on the road when I would flat tow one home, they were not difficult.
Jim
Old Jun 17, 2015 | 04:38 PM
bobva's Avatar
You really mean every couple of years.
I rebuilt my Rear end & Brakes in 2012. this year I did some brake work which included the right Ebrake cable. SOB was clogged.
Old Jun 25, 2015 | 11:25 AM
10 Year Member
Had to fix that pesky brake clip...
Originally Posted by j_martin
Mine were totally missing. Here's my "temporary" fix.
Takes a cobalt drill to get through the case hardening of the lever.
Went to apply the brake last night and that stupid clip popped off. Took it all apart again and of course there it was in the bottom of the drum. Got to thinking about how the GM cables attach much better, so just happened to have a set laying around and this is what we came up with. Much better than that 'donkey' way dodge dit it. Plus it will save having to tear into again because that clip is not coming off again.
Old Jun 25, 2015 | 03:28 PM
10 Year Member
Seriously apologize for the huge pics - thought they were resized but guess not.
Old Jun 25, 2015 | 03:56 PM
bobva's Avatar
I like the size of the last 2 pics I can SEE.
