Pulling my hair out!!! Need Advice!!
Old Oct 21, 2013 | 09:37 PM
  #31
maybe368's Avatar
Originally Posted by NJTman
You look a little different, in person, than I thought you would..... but I like your voice !
Thanks T for the recognition, but I still can't stay in the hotels that I perform in. Did I remember to tell you that I did it my way?...Mark
Old Oct 21, 2013 | 10:24 PM
  #32
Sorry Mark,
I must have mistaken you for Sammy Davis JR. Your PM showing me your real video made me see my derailment
Your tone is a little off, here, but I think that you did a fine performance anyway..
Old Oct 21, 2013 | 10:50 PM
  #33
maybe368's Avatar
Sorry Mark,
Your tone is a little off, here, but I think that you did a find performance anyway..
You got me T, but you know what? I really hated it when I died......Mark
Old Oct 28, 2013 | 11:26 AM
  #34
whosdunit's Avatar
Say guys I'm hav'n the same trouble w/ my OD ,I can't seem to find the sticky on this ,and i'm not sure what the CPS looks like( my d250 91.5). Just replaced the VSS( 52.00) is there a pic. to look at .?
whosdunit.
Old Oct 28, 2013 | 12:07 PM
  #35
mknittle's Avatar
To me The comment read post 9 did come off as somewhat condescending. I was reading the thread to see what he problem was (just for future reference) My truck is older and I would have no reason to now sensor values(that I do mot have in the first place) so not all of us have a CPS!
Old Oct 28, 2013 | 12:19 PM
  #36
93-331-29psi's Avatar
Originally Posted by Ghosthider
Ended up replacing it, darn thing wasn't cheap. On a side note how much movement is normal in the belt tensioner? Seems to bounce more at idle, just noticed as I put on a new belt, never really noticed with the old belt.
It will bounce a little, but not too bad. Does the belt track correctly on the tensioner? I replaced my belt and everything went to hell. Replaced the tensioner and the belt still tracks wrong and makes contact with the tensioner arm.
Old Oct 29, 2013 | 04:05 PM
  #37
whosdunit's Avatar
Did the tps adj. according to the stiky !!!test drove till therm at norm. operating ,then zipped up to 80-85, let off to 55 ,,,,smooth as it should be. M tps has a plastic 2 sided nut for adjustment,barly turned it counter-clock wise to get readings. Thanks (AGAIN)
whosdunit.
Old Oct 30, 2013 | 04:43 AM
  #38
KRB's Avatar
KRB
That was a cheap fix. Glad you got it figured out.
Old Oct 31, 2013 | 05:33 PM
  #39
Ghosthider's Avatar
Sorry was out of town hunting. Belt tensioner is no longer moving so most likely debris. So the cps sensor solved the charging issue still have no cruise and only get OD with the switch I installed on the OD solenoid. I am guessing a wiring issue, any suggestions where to start.
I am sorry for the issues with post 9, just a long day, I did mean .050 and was only looking for reassurance of what I found. You guys are all great, thanks for all the help.
Old Oct 31, 2013 | 05:40 PM
  #40
mknittle's Avatar
Some days are like that. I had mine yesterday
Old Nov 1, 2013 | 07:34 PM
  #41
whosdunit's Avatar
AHHHH,,Crud,,wrong,,,,OD kicked out between 60-65 ,finally droped back in at 45-50,then stayed.The "O" parts house say new TPS "315.00" will be going w/ 89-90's Dakota tps fix.
whosdunit.
Old Nov 3, 2013 | 12:43 PM
  #42
Ghosthider's Avatar
Question
Sorry guys have to ask again. The cps sensor solved the charging issue still have no cruise and only get OD with the switch I installed on the OD solenoid. Any suggestions where to start isolating? I am guessing its wiring but no clue where to start. Unfortunatly I cant afford a service manual from Genos, just had a baby girl so any help is greatly appreciated!
Old Nov 3, 2013 | 01:46 PM
  #43
Did you ever swap the relays under the hood as stated in the sticky ? Wouldn't cost you a dime to do so, if you did, and you'd find out if the center relay for the a/c is bad or not.
Old Nov 3, 2013 | 05:17 PM
  #44
j_martin's Avatar
You might as well park it. If you can't afford a $35 manual for it, you can't afford the fuel.
Get the CD. Print only the page or 2 you need for a particular problem.
Old Nov 3, 2013 | 08:07 PM
  #45
Greed 93's Avatar
Who the hell are you to tell someone to park there truck ! The guy just had a kid, maybe he can't get the manual cause he put money in fuel or food ?! If you really need to use comments to other people on here to make you feel better about yourself get a new hobby.
