pcm part number
hi guys
looking for a part number for a pcm for my 92 w250 le, 5 speed. the dealer is coming up with two different options and i cannot find a tag or any numbers on my old pcm for them to reference the correct one. anyone know which one i need or the proper part numbers thank you justin |
If you look up the PCM on Rockauto it lists all the part numbers for your vehicle.
The dealer should be able to pick the right one with your VIN no?
Sent from Tapatalk 4 via a Galaxy S3 |
acording to alldata...
4723106 |
Question, what does the PCM control? Does it control the speedo?
Originally Posted by bannerd
(Post 3208711)
thanks guys, and the dealer came up with two different part numbers for the pcm
If the truck and the original PCM are still operational, the factory scan tool is capable of reading and displaying the part number. No idea whether aftermarket scan tools can do it.
Originally Posted by oilcan64
(Post 3209117)
Originally Posted by maybe368
(Post 3209175)
According to Rockauto's site, Their part# is STANDARD MOTOR PRODUCTS Part # EM10804, which replaces all of these OE part #'s 56006024, 56027082, 56027571, 56028082. These are all for the standard trans. Apparently, they have them in stock too...Mark
While they are listed, whenever you go to checkout it gives you a "this product is discontinued" error and they remove it from your cart. I have been looking for a new PCM for my '92 for some time now. |
Originally Posted by tacoAGGIE
(Post 3209464)
This morning my grid heaters kicked in several times at about 40* F after I had driven more than 100 miles. Clearly this is not supposed to be happening and my guess is my Powertrain Control Module has a gremlin.
The Mopar new part number for a PCM to fit a 1993 automatic was originally 5602 6861, and later the Mopar remanufactured part number was R4746 568. Both numbers are now discontinued and the Mopar computers show no dealer in the US as holding either unit. I've been recommended two separate shops, both in Florida, that remanufacture PCMs. (Rock Auto carries reman units from Cardone, a brand I would prefer to avoid.) The going charge for a core seems to run from $65 to $125. If possible, I would like to keep my current PCM as a spare -- if anyone happens to have a junk PCM that he/she could sell me to use as a core, please PM me. TIA. |
I would suspect that it's actually your Air intake Temperature Sensor is going out. If it sends a false signal to the PCM, then the PCM will fire up the grid heaters.
I was having this same issue with my KSB. Turned out the AITS was shot. ;) |
(Post 3209464)
(Post 3260580)
Originally Posted by wheelerfreak
(Post 3260584)
This has been what I've found from a bunch of places I've tried. The only place that had one was a junkyard and I don't really feel like taking a chance on a 20 year old used PCM. I've just bypassed the grid heaters, added an external voltage regulator, manual OD switch, and learned to live with no CC.
