Overheating
If you have replaced all the cooling system parts, though, it sounds like you may have a blockage in the block. I would build a contraption like the one that Jim Lane built that connects a garden hose to the top of your block. Then crank up the hose, and watch the water coming out of the block at the lower coolant hose outlet. You should be able to tell whether or not the water is exiting the block at a normal garden hose rate-of-flow.
I'm thinking the same thing.
Just needed someone else to chime in and agree.
And to maybe pop off with something I'm overlooking.
If something crushed all the vanes on the A/C condenser, then, maybe that's involved and there's something to the air-flow theory. Worth a try before you throw away a bunch of perfectly good anti-freeze.
One other thought, does the engine over-pressurize the system and puke the radiator? Any chance of a load-related head gasket leak into the cooling system? What made the original, then the custom radiator fail (overpressure?)? Have you had an exhaust-gas-in-the-cooling-system test done?
Brand new fan clutch.
Fluids topped up.
AC cond. is trashed. The fins are so beat I can't spray water through them to clean it. Old rad started leaking. It was a custom 4 core to boot.
I think I'm going to try flushing the block first and see just what comes out of it.
Fluids topped up.
I had a very similar problem on my truck (it was my old ford, but the concept is the same). It was mid-winter in Wisconsin, and I had recently put new coolant in it that was mixed 50/50, and the truck sat for a while, and when I got it out, it was fine until I reached about 55-60 mph, and then it would overhead almost instantly. I screwed around with new thermostats and stuff for a while before I realized that my radiator was plugged (bottom hose off, and coolant still visible in top tank). I took the radiator out and took it to a shop to have it rodded out. They called me a couple days later saying that nothing was wrong with it. Then it dawned on me that the coolant must have froze in the radiatior plugging it enough to allow in town speeds, but nothing more, and when the radiatior sat inside the shope overnight, it all melted out. I put the rad back in with new coolant again (not the cheap candy this time), and the truck has been fine ever since. Might be something to think about...
Head gasket is new and not a concern
I don't know, it just started leaking but I'd been tinkling around with the fan, belts, etc so I'm thinking I just nicked it. (I'm an expert at wrecking things!!!)
I've never heard of that test before....
Try taking out the condenser and replacing it with a cooling fan or 2. This may solve the heating problem, but doesn't fix what is causing it. I think that there must be an obstruction to air flow, i.e. condenser, or obstruction to water flow, i.e. plugged water galleys. There is so much reserve built into these rigs that, where you live, heating should never be a problem...Mark
I have never used my AC up here.
I like the Iraq/Afghanistan heat!!! It's never too hot for me weather wise. Getting real tired of snow as I get older.
If I take out the condenser I'll need to take off the ac pump as well no?? I sure the coolant is also a lubricant. Would I need to use a different serpentine belt??
Maybe someone more knowledgeable will chime in, but I don't think you have to worry about the compressor, it only spins when the clutch is engaged. That way you just remove the condenser and cap off any open ends, so not too much contamination gets in. The system should be easily restorable, if someone wants to down the road...Mark
I have lived in Phoenix almost my entire life and I have learned to really appreciate the heat. I like it, the hotter the better. But then. after 3 months or so of it, i really like the 9 months of not hot and not cold season. I think heat is much healthier than cold and cold is something to be visited, not lived in...Mark
...Mark
