OverDrive location
Hello folks! I’m trying to locate my OD plug! ...I’ve found two plugs on the driver side of the transmission. One has two wires and is going into a tube...I’m assuming the temperature sensor....but I’m not sure. The other has three wires going to it. These are the only plugs I can see. Can someone tell me what is what? thanks, Tony |
Three ire plug horizontally oriented is the neutral safety switch. Above and slightly rearward there is a two wire plug vertically oriented, that is your OD plug. The two wire plug in the cooler line is the high temperature sensor.
Thanks! I found it....☺️ |
