OverDrive location
OverDrive location
Hello folks! I知 trying to locate my OD plug! ...I致e found two plugs on the driver side of the transmission. One has two wires and is going into a tube...I知 assuming the temperature sensor....but I知 not sure. The other has three wires going to it. These are the only plugs I can see. Can someone tell me what is what?
thanks, Tony
thanks, Tony
Three ire plug horizontally oriented is the neutral safety switch. Above and slightly rearward there is a two wire plug vertically oriented, that is your OD plug. The two wire plug in the cooler line is the high temperature sensor.
nonrev (09-20-2018)
72demon440
04-27-2007 10:45 PM
