One ton tailgate light measurements....
5 Attachment(s)
OK as requested here are the pics, and measurements I took off a 1992 Cummins D350 reg cab dually tailgate. The tailgate was damaged, but in great shape.
So if you want to install lights in the correct location, here are all the pics, and measurements you will need o make it look factory correct. Attachment 51583 Attachment 51584 Attachment 51585 Attachment 51586 Attachment 51587 |
4 Attachment(s)
Attachment 51579
Attachment 51580 Attachment 51581 Attachment 51582 Measurements for the light mounting is a .865" hole in the middle, with an outer spacing of the screws set at 3". |
4 Attachment(s)
Attachment 51575
Attachment 51576 Attachment 51577 You can see the hole with the small body plug right under neath it. That is the dead center light. The center of that light is set at the exact middle of the tailgate. Attachment 51578 |
2 Attachment(s)
http://i697.photobucket.com/albums/v...5.jpg~original
Attachment 51573 And the hole, and notch required for the wiring to pass through. This is on the LH side of the tailgate. Attachment 51574 Hope this helps. ;) |
Guess just in case these photos disappear there should be some hard text measurements.
There are 5 lights. The middle of the center light is placed in the exact center of the tailgate. Then the next two lights, to the left and right of the center light are placed 7.5" center to center. The final two lights are placed 22" center to center off the last two that were installed. So about 29.5" center to center off the 1st light. |
Mr T-Cow
That was a beautiful LE tailgate, how did it get hit from the inside out? |
Originally Posted by Jim Lane
(Post 3255829)
Mr T-Cow
Wow..
That hurts about as bad as backing up with your door open and snagging a fire hydrant. |
1 Attachment(s)
TC, thanks to your hard work, I came up with this.
You just gave me an idea for more LED signals.
Originally Posted by 69HemiGTX
(Post 3255933)
Originally Posted by NE frmhnd
(Post 3255961)
