o/d
Old Dec 18, 2006 | 10:52 PM
loch's Avatar
o/d
We talked about putting a newer tranny in our trucks, but they needed vacuhm that varies with acceleration. So my question is, can we use a boost switch ? The vacum switch cuts the tranny out of o/d when you punch it and vacum drops. If we used an adjustable boost switch and a relay if we punch it boost goes up and cuts relay out. any ideas ?
Old Dec 19, 2006 | 05:35 AM
JD730's Avatar
I would use a manual toggle switch to keep it simple.
Old Dec 19, 2006 | 06:23 AM
dart3404's Avatar
not sure what u are doing but of the top i cant think of a chrysler trans that needs vac
Old Dec 19, 2006 | 02:31 PM
loch's Avatar
Hum ok better explanation, if we use a 94 tranny its an o/d with lockup. you can use two oil senders in a port on pass side, at a given pressure the o/d will come on and at another it locks up. On gassers they use a vacum switch to basicly drop it out of o/d when you punch it, gives you a passing gear. but vacum on our trucks is constant. this site explains it better.
http://www.transmissioncenter.net/SwapInformation.htm
push button is a pain at best at least on lock up
Old Dec 19, 2006 | 04:39 PM
ChrisLib's Avatar
you could also wire in a microswitch ~ala a Nitrous setup to open the O/D circiut when you want a given % of throttle
