Nozzles or Injectors
Old Nov 18, 2011 | 05:26 PM
DodgeFreak's Avatar
I'm looking at getting injectors and am tring to decide if i should but the whole injector or just the nozzles. is there anything i should look for with my injectors to know if i should buy the whole injector or if i can use nozzles. Thanks
Old Nov 18, 2011 | 05:52 PM
BC847's Avatar
1st Generation Admin
You can use just nozzles if you have access to a Pop-Pressure Tester so as to set the injection pressure.
While all the nozzles out there should be identical in dimension, things are sometimes off a little. Watching the gauge on the tester while flowing diesel fuel tells you if you need more shims, or less, under the spring in the injector.
There's a gazillion different shims and combinations of shims available to get all the injectors to Pop at the same pressure. (small thing in the black square)
Stole this image from Smokem
It is important to have them at pop at the same pressure.
Or you can get complete injectors that are already set-up. (You'll typically have to send your old/used injectors in as Cores so don't damage them).
Old Nov 18, 2011 | 06:28 PM
DodgeFreak's Avatar
ok thanks I have access to a pop tester. Where do i get the shims?? Sounds like nozzles will be the best way for me. Thanks for the pictures
Old Nov 18, 2011 | 06:59 PM
kensmachine's Avatar
BC have you ever lit the spary from the Injectors whene testing then it make a nice fire ball
Old Nov 18, 2011 | 08:07 PM
BC847's Avatar
Dunno. I've looked online and can't find any. Those in the buesness arn't giving up any secrets and seems like I've heard they can be purchased, but they're $4(+/-) each. Seems I recall they can be had in 0.003" increments.
I got lucky and was able to borrow a large selection from a fella.
Nah, My Dad and Brother both have substantial scarring from them or somebody else playing with fire.
Besides, with me being a former FF/EMT-D of 14 years, the wife and both daughters on the same FF/EMS dept still, one the daughters being a 911/EMD op and the other a full-time paid FF/EMT-D . . . . . I'd never hear the end of a "Hey y'all, watch this" . . . .
Old Nov 18, 2011 | 10:00 PM
9453's Avatar
I've herd that Hot cams shim kit for KTM 250 450 and 525 dirt bikes. fleebay has them for like $50 for the kit. hope this helps
Old Nov 18, 2011 | 10:22 PM
BC847's Avatar
VERY interesting! Thanks for the tip.
WestTexasRam
Oct 4, 2006 03:38 PM
WhiteRamDiesel
Mar 8, 2006 02:00 PM
singleturnout
13
Jan 18, 2006 06:14 PM
killfast1
40
Jul 7, 2005 04:15 PM
macaw
Feb 10, 2005 12:38 PM
