Not fueling like it did
Hey everyone, ive been a member for a little while but never posted because all the info i have needed was in the stickys. This one isnt so here i am.
truck used to smoke like a freight train with the turbo spooled, now it only smokes with turbo not spooled. ive replaced fuel filter, checked fuel psi like 20 at idle and lowest ive got it to drop raw doggin it is 10 psi. ive cracked each of the injector lines and rpms drop like they should, took afc top off and the fuel pin is moving like it should. Any suggestions of what to look for now? Im lost
91 Dodge W250
366 spring, denny t pin, m&h timing spacer, bhaf, piston lp, fuel screw turned, 6" hood stack, allied precision clutch, isspro boost/pyro/tach
91 Dodge W250
It has a small miss to it when its above idle. Boost I havent really lost much maybe 1-2 lbs but it used to snap right to 30 or so. Now it doesnt boost as fast it seems. And it used to black out the road behind it. Now there is just a light haze. Idk how it goes from an extreme amount of smoke to a light haze in the 6 month period I've had the other turbo on
supr
Jan 5, 2010 09:11 AM
Ph4tty
27
Aug 15, 2007 01:21 AM
