no start
well i got all the valves adjusted using the timing pin and instructions from the sticky, and it still cranks very slowly, what do i check next? and yes the voltage drop is from the battery while cranking
well its not the electiral system to the starter then i dont think, have you tried haveing a batt, charger on it and cranking it?, is it a auto or stick truck?
recheck the grounds also mainly the one on the block and make sure the batt cables are clean and have good contact, might be worth trying again
yeah tried the battery charger, its an auto, one battery is grounded to the frame, the other is above the fender, are those bad locations? by the way i just noticed your location, i got my pickup from power motors in sublimity, got a decent deal on it too, any more of em down there?
these came stock with one battery, it should have one cable, large size going to the block under/near the vacume pump,and a small wiregoin to the core support.
they might have more trucks out there, dont know, i got my blue truck from washington, so i bought mine up there and you got yours down here
yeah the main one had only the small ground, so i put a big one to the frame, anyways a mechanic is coming to look on monday, so i'll post what what the deal is when he gets it running
