-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   New stocker, Aftermarket upgrade, or Electric Upgrade ? (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/new-stocker-aftermarket-upgrade-electric-upgrade-304495/)
NJTman Jul 1, 2012 11:25 AM
Just trying to get the feel for the majority here.
Do you, when your fan blade starts to...or goes bad....
A. Replace with OE
B. Replace with a better quality steel / FG blade
c. Replace with Electric
d. Other
If you could state reasons, and / places you purchased it would be helpful to others trying to make the decision on how to ....
TIA
wannadiesel Jul 1, 2012 11:33 AM
OE replacement. Electric is not enough flow, there is not an aftermarket fan better than OEM.
00 PAU
Sent from my Paranoid Android HD2 using Tapatalk 2.
dieselJon Jul 1, 2012 12:08 PM
Depends on if you are towing.
I towed around 10k and it got warm. However, I had a head gasket issue. Also, I need to clean it out, both inside and out.
This truck also nets me more average MPG than my last 2.
If I were to do this over again, I would get a 2nd Gen radiator and a Taurus SHO fan. IIRC, flows something like 3200cfm. Requires a 70amp relay for the high setting.
93flatbed Jul 1, 2012 08:51 PM
I don't tow so electric for me. I got one from a SSR, no idea what it flows but it cools my pile in Arizona heat with good a/c. My other 1st gens I tow with have the stock units. But I check them often for cracks, I've replaced 2 blades over the years due to cracks.
d22019 Jul 1, 2012 10:35 PM
I replaced the fan and clutch with 2nd gen parts in my '93. The fan is 10x quieter and it worked great in the arizona heat I towed in this week. Everything bolted in place with no modification. I rounded up the fan from a junkyard and the clutch from a dodge place online. The clutch was listed as a more aggressive snow plow clutch. I have around $150 in the set up.
NJTman Jul 3, 2012 06:16 AM
This sounds most promising..
Did you get your stuff from a 12V or a gasser ? Seems that it would be easier to find the 2nd gen parts than our truck parts. Other than the dealer, I don't even know where to find an OE fan. Will have to do some searching on this one.
Thanks !
bannerd Jul 3, 2012 06:21 AM
00 PAU
I second this.
d22019 Jul 3, 2012 09:16 AM
I got the parts for a '96 cummmins. I think 94-02 are all the same.
NJTman Jul 4, 2012 12:05 AM
1990-1998 are all the same according to the supplier on Ebay that is an actual chrysler dealership.
Dodge Ram Diesel Engine Cooling Fan Blade 52028653 Mopar 5.9 Cummins 90-98 12val
Good to know guys, thanks again !
dieselJon Jul 4, 2012 10:39 AM
1 Attachment(s)
Hope this helps the electric crowd.
1 single Lincoln Mark VIII/Ford Taurus 3.8L V6. They have dual fan setups. Gloves were dropped above and 5-6" away from the coolers.
Attachment 56941
NE frmhnd Jul 4, 2012 11:43 AM
Would a small electric fan mounted say, to the back side of a grill guard, pushing a little air through to the fan clutch, help keep things cooler in traffic and in town?
1972RedNeck Jul 4, 2012 12:48 PM
^I was wondering the same thing. Is there a small pusher fan that could be mounted behind the grille?
NJTman Jul 4, 2012 01:13 PM
Not on my truck...
My intercooled 92's grille has just about enough room to fit a 8 gauge wire through (including plug) for my snow plow. Smaller or larger (but not much) depending on where you are in relationship to the grille.
The A/C unit condenser eliminates the possibility on mine.
Maybe NON IC and NON A/C would work.
d22019 Jul 4, 2012 06:16 PM
I have a friend with an intercooled '91 that has a small fan on the front. Its really really thin and about 12" in diameter. I'll try to get pictures and more info next time I see him.
1972RedNeck Jul 4, 2012 07:25 PM
http://www.summitracing.com/parts/BCI-75059/
