need help with some fixes on my 92
Old Sep 25, 2012 | 11:50 PM
td3620's Avatar
Question need help with some fixes on my 92
About 3 monhs ago my clutch started being very hard to push in.i drive it every weekend.it has no problems shifting or going in gear,just the clutch is hard to push in.
The other thing is im trying to get my milage to work.dont know which gears to replace.speedo work though.
my cruise control dont work and i want to get it fix before next summer.and is there anybody have a problem with there power window on drive side.one day it will roll down.go about 2 weeks,it wont roll down.but i can press the button and it has power going to it,you can hear it. if yall dont mined helping me on some oh the things.Thank you wesley
Old Sep 26, 2012 | 05:51 AM
deanhinsley1963's Avatar
Clutch could need the linkage lubed. Get underneath and observe while someone works clutch from inside. Look for binding or twisting. Does your speedo work but not the odo.? If so need to change gears in the speedo head. There are stickies on how to do this. If speedo does not work at all,or cruise either could be the v.s.s. vehicle speed sensor on the trans. This is what the speedo wires connect to just screws into the trans. Hope this helps.
Old Sep 26, 2012 | 05:19 PM
td3620's Avatar
ok thanks for info,the speedo works fine,but not the reg.horn or cruise control
Old Sep 27, 2012 | 08:32 PM
Chrisreyn's Avatar
If the speedo is working fine, but horn and cruise are not, you may have an issue with the clock spring, read the Stickeys for more info on this.
excerpt:
"Important note on steering shaft replacement: DO NOT spin the steering wheel with the shaft disconnected. Some of these trucks use a clockspring to run the horn and cruise, break it and it's about $150 to fix it. Tie the steering wheel to the seat frame before you disconnect the shaft."
cseby
Mar 13, 2011 12:00 PM
bkrukow
39
Apr 23, 2004 04:52 AM
TurboPirate24v
Mar 9, 2004 05:07 PM
ryker
Sep 23, 2003 09:58 AM
hellotbone
16
Mar 31, 2003 08:28 PM
