Modified Mirrors - Tow mirrors with a twist
Well with my latest purchase of a frame with the cab forward sheet metal has pushed up my projects. Poor old Moose has a bad case of cancer, so the body was in order.
Now I have mentioned that this is about mirrors, so here goes. This is a variation of what Bruiser has done in the sticky: https://www.dieseltruckresource.com/....html?t=150798
Well first off, toss the factory mirrors and spend a few hours welding the holes in
Then spend a few hours making brackets.
Once that is done it is time to skin the brackets.
I am not an overly patient man when it comes to having to see what the end results are so here goes.
These mirrors are from **** and are heated and power. The extension of the mirrors are manual. These are made for GM truck 88-98. I know none of the finish body work is done in the pics, but this weekend it is getting sprayed. Yes the body work is done now.
Here are a few more pics.
Nice work but aren't the bracket a little too far toward the rear of the door ?
I know some people don't use the vents but I love mine and can't stand the new one piece windows. I crack mine even in the winter to keep air flow thru the truck. And nothing feels better than the vents turned all the way around and having the air blow directly on you at 70 mph - ALMOST as good as A/C when the temps and humidity are below 90* ...
). I will have to put in the vent windows and see. The truck getting painted has been pushed back. Darn work wants to make money this weekend rather than spraying my truck for just the cost of materials.
Bruiser, Thanks and for sure no shaking. The angle iron is 3/4" . It will give me some viewing also, **** calls these mirrors 10" x 10". I know on the GM they were night and day compared to the factory mirrors.
On the old truck it didn't matter. With the mirrors being powered, all you do is adjust them to check the tires. Pulling my 5ver it is hard to see the tires as it is. I am more worried about the idiots behind me.
If I could still find the 3 1/2 inch bracket-mount spot mirrors I would mount them up on the edge of the hood somehow.
Well spent some time today and got the truck painted!
Here are the mirrors installed.
If you want to look at all the progress then here is the link to my photobucket account: http://s31.photobucket.com/home/ruralcruiser007/index
This is only a small part of the truck build, so when it is all done I will start a new thread showing everything with description.
Note: Darned if I know why but on photobucket all the pics are rotated right.
Thanks!
This is just a little part of the overall project. Now to make the custom flatbed. Take the drive train out of Moose and put it in Moose 2.0. Rebuild the Getrag, tcase, D70, D60 and head studs. Oh and then need to finish the exhaust.
I didn't mention, but Moose is my daily driver. So the change over has to be on a long weekend. The rebuilds can be ongoing. But the change over has to be done on a long weekend. The axles that are under the frame are a D44 on the front and D60 on the rear. Nothing a few hours and lots of coffee wont fix.
Jblak87
Mar 26, 2012 05:30 AM
DUKCALN
Jul 1, 2008 12:19 AM
B.A.Ram
Jan 12, 2006 07:29 PM
1320
Apr 30, 2004 09:13 AM
