Lots of smoke at cold start, would like it to go away
As far as the old lift pump, I kind of wish I would have checked pressure prior just to conpare. I peeled apart the old lever lift pump and inspected the diaphragm. I seemed slightly dry and on the underside when I folded it back there was a little stress cracking, but nothing that seemed to go all the way through. Although I am sure it's possible to have a microscopic leak. I didn't notice signs of oil either, just diesel.
Ignore the 3 slits. It's how I took it apart.
Oh and one more thing; I found a boost leak which explains why my gauge read low after swapping injectors. When I took things apart to install the injectors, I inadvertently cracked my 1/8" nylon boost tie that goes to the gauge in the cab. It cracked right at the brass compression fitting where it enters my pusher intake tube. I knew this would happen some day. Auto meter provides a brass compression fitting for you to install their gauge boost tube into your intake, but it uses a brass ferrule/compression fitting. When in reality one should really be using a delrin/plastic ferrule since it is going on a plastic tube. Can't find any plastic ferrules so I ordered another 1/8" brass one. For now the intake mani is plugged and the boost gauge reads zero
. Which doesn't matter because the truck is now in the shop ha!
Or just use an Isspro boost gauge which uses an electronic sender in the intake to convert into a gauge reading
I think the spray angle issue is overblown. May make a difference on 5x12 and above, but not much if at all on the 185s, 190s etc. as always, nozzle projection and timing help.
PurNLoud
25
Mar 23, 2006 11:01 PM
tschwab
13
Dec 11, 2005 08:19 PM
