Lets see your gauges! (picture thread)
Old Jan 28, 2012 | 07:21 PM
  #151
elephantrider's Avatar
its a steering column mount for the 94 - 98 2nd gen trucks.
Old Jan 29, 2012 | 09:17 AM
  #152
thrub's Avatar
Originally Posted by elephantrider
i dont see how some of you guys drill into the dash and hang gauges like that, or cutting holes in the front bezel. i couldnt do that.
I have several panels if I want to switch back to stock at a latter date. With the gauges in the panel there are no holes in the dash.
Old Jan 29, 2012 | 10:06 AM
  #153
bill-d-c's Avatar
I've seen those in Geno's catalog (single column mount). How much tweeking do you have to do to get them to fit our trucks? Looks good, like something the factory "should" have done.
Bill
Old Jan 29, 2012 | 10:07 AM
  #154
ah okay, well that would be fine. i guess i need to get a few extra dash pieces just for that reason.
Old Jan 29, 2012 | 10:22 AM
  #155
peckens's Avatar
out of curiosity, What is so different between the two? Does it not mate the bottom on a 1st gen correctly?
Old Jan 29, 2012 | 11:47 AM
  #156
Moparbubba's Avatar
The tilt column is the same as the newer trucks
Sent from my DROIDX
Old Jan 29, 2012 | 11:58 AM
  #157
bobva's Avatar
added a sunpro oil pressure gauge this morning. it runs about 45lbs @ idle and up to 85lbs @ wot. kind of nervous about running oil into th cab, but should be okay.
This is made for fuel pressure but I use it for Oil pressure also.
http://www.dieselmanor.com/dm_products/DM-CGI2240.asp
http://www.dieselmanor.com/docs/dmi/...ions_rev42.pdf
Old Jan 29, 2012 | 12:47 PM
  #158
Onemoparnut's Avatar
Bill
There is no tweaking it is a direct fit. I still have no idea why they aren't listed to fit our trucks.
Old Jan 29, 2012 | 01:35 PM
  #159
delsilver's Avatar
My understanding is they will only fit ours if you have a tilt column but will fit all second gens.
Del
Old Jan 29, 2012 | 02:24 PM
  #160
i've also read it only fits the 1st gen columns with tilt as well.
bobva - that looks like a good idea, i may just go ahead and redo it with an isolator installed. thanks for those links.
Old Jan 29, 2012 | 03:08 PM
  #161
bobva's Avatar
Glad you like It
Old Jan 29, 2012 | 05:39 PM
  #162
The 94-98 Column pod will fit a non tilt column, i've done it twice before
Old Jan 29, 2012 | 08:43 PM
  #163
DJ Turbo.'s Avatar
i just dont wanna have a hacked up interior. some parts are hard to find, and some you cant find, so i want to keep the dash together as much as i can.
Makes sense man
Old Jan 30, 2012 | 12:23 AM
  #164
stillsmokin209's Avatar
Cant see the boost gauge in the pic, its in a cup on the A pillar.
Old Jan 30, 2012 | 07:24 PM
  #165
CE_TX's Avatar
Very nice!! I like the green lights.
