Leaf springs
mknittle (04-29-2017)
I put SkyJacker springs on mine. Alcan is also another option, the will custom build them for you also, they have a form online you can fill out and then they will give you a quote. The more information you can give them, the better. http://www.alcanspring.com/
I stuck with OEM springs. Might surprise you how little lift or extra travel can play havoc on your drive line, especially in the front.
When I made my front hangers I made them to do the 52" Chevy rear spring swap later on If I ever get around to it.
Like some of the other guys mentioned get some longer chevy springs, that would be the best if you don't want to put in a lift kit.
I just installed the stock lift 3 spring front springs from custom suspensions. on my 92 and put the pro comp es3000 shocks all the way around and have to say I'm very impressed with the ride. the wife says it rides better than her 98
Install spring tip isolators (bushings),
Instead of the spring tips grinding against each other as the truck rides, they slide effortsly giving you a better ride.
I also installed hydraulic shocks.
Jim
Jim
springs
i have lift spring on the front of my truck. I nead to know how much lift they are. does anyone know of any good measurements for stock and 4" lift
