installing holset HE351cw. need all tips/tricks
i'm gonna install this turbo soon. ordered the block off from ats for the eletric stuff.
please let me in on any tips/tricks or hints on installing this or any other turbo for the matter. i have to make a downpipe, so i need to source the holset endcap. please, lets hear all about your install! i'm worried about the oil feed and return lines! |
the oil lines will work with no problem. you just have to clock the turbo to line them up. It is a pain to clock the turbo though. you have to loosen the vband and the snap ring both. I ended up using needle nose vice grips to do this. You need realy big snap ring pliers and i couldnt find any local. you will have to weld up and fabricate IC piping as well. you just need a 4in vband flange and 4in ex pipe to weld together to make th DP work, Overall its easy as long as you can weld ex pipe
