I think its going
Old May 26, 2004 | 10:46 PM
dodgeman01's Avatar
I think its going
well after 200k my auto in my 93 is starting to show signe of wear. when put into gear after sitting a day or so the truck takes about 5 seconds to move. it don't matter if you have it to the floor it will still sit for 5 seconds before it starts to move then after that it is good all day. is this just the drain back valve or something?
DM01
Old May 26, 2004 | 11:10 PM
DJ's Avatar
DJ
As things wear the converter leaks down faster, sounds like you have some worn bushings and internal seals/o rings. If its still running ok after it primes I'd keep on driving it.
Old May 26, 2004 | 11:28 PM
dodgeman01's Avatar
it runs fine but every once and a while it does not know what gear to be in. but usually it is fine.
DM01
Old May 27, 2004 | 09:24 AM
apache's Avatar
My 93 2wd has been like that for 3 years now, I still tow, and use it like normal and no problems. When you fire it up to warm put it in neutral, this will get the trans fluid pumpin.
southpawslingr1
Jul 9, 2008 08:44 PM
NO1B4ME
Apr 24, 2005 08:23 AM
z1bigtom
Apr 4, 2005 06:36 PM
SuperDave4x4
Jun 21, 2004 06:10 PM
DieselDaze
Jul 17, 2003 09:21 PM
