HX40 Vs. Upgraded H1C
I have decided to drop some money into a turbo, inter-cooler, and exhaust system for my truck. For turbo's, I either want to upgrade my H1C with a 60 mm compressor and 16 cm exhaust or find an HX40 with 16 cm exhaust.
Which is better? Which one would give me lower EGT's? Which one would spool faster? I would like to decide which I am going to use so I know which down pipe to get. Also, what year Ford inter-coolers work the best? And where do I buy boots? |
Bump
You want to get the earlier 99-01? intercooler with the aluminum tanks. The plastic tanks tend to blow apart at high boost.
Originally Posted by d22019
(Post 3144924)
So what is all your opinions on turbo's? I have read that the HX40 has a larger exhaust wheel. Is this correct? |
I would go with the 351cw, spools fast, cools well.
I need to lower my EGT's a lot. I can easily hit 1500* in fourth on flat ground with no load. I would like to change the fuel pin and turn the power screw in farther. I don't want to run water/methanol or twins at this point in time.
The HE351CW has a 9cm exhaust housing with a 4" + outlet, correct? The HX40 has a 16cm exhaust housing and a 4" outlet. In my mind, the HX40 should keep my EGT's a fair bit lower. Is this correct? I would rather have more useable power for pulling than a fast spool-up. |
I don't think the 40 will lower them that much more than a 351, the "super 40" (best of the 40's) and 351 have the same compressor wheel. Many report the hx40 is somewhat slow to spool.
Originally Posted by BILTIT
(Post 3145147)
Has anybody ran both a super HX40 and HE351CW (at different times of course)? Which ran cooler? |
