How wire 2nd gen column shift overdrive button in 1st gen
I've read in the past about some 1st genners using a 2nd gen column shift (with overdrive button) to activate overdrive in a A518. The 2nd gen OD push button is a momentary switch and will engage OD when depressed, but will disengage OD when it is released. I think I need to wire in a latching relay, but can't find any diagrams etc for this. Can someone please direct me to this information. I asked this question in another thread on governor pressures, but that thread went nowhere. TIA
It is a momentary switch just like the one on the dash. All you have to do is wire it in parallel.
Originally Posted by cougar
(Post 3307483)
1 Attachment(s)
i believe you want a toggle. i did this in my cummins swap project with an a518. you just wire one side to ground and the other side to the solenoid. "on" and it will act as normal "off" and it will not shift into overdrive.
Attachment 49248 |
If I'm not mistaken, there's a thread in The Sticky regarding what you're wanting to do.
Originally Posted by j.fonder
(Post 3307494)
http://i62.photobucket.com/albums/h8...pshcc4jgsh.jpg |
What you want is a push on/push off switch, not a momentary. Which means you cant use the shift lever button unless https://www.dieseltruckresource.com/...nction-315554/
Sounds like you need a simple impulse relay to make it do what you want.
(Post 3307568)
Was it OEM and if so what truck/car had it. I've found a bunch of aftermarket rocker switches on EBAY which are close fits and I suspect that's what you used. Please inform me. By the way, bro, I lived in Alaska for 17 years, in Port Armstrong on Baranof Island, 100 miles from nearest road (Sitka) brownies big as our trucks (not quite) - best years of my life despite nearly starving and living on clams one severe winter. Thanks for the help! |
Originally Posted by 1972RedNeck
(Post 3307575)
I don't know how many amps it takes to ground the OD solenoid and hoping it's less than 2 amps. Does anyone know? Thanks again! |
I wired mine just like the sticky said. All it does is add another button (on the shifter) and I use it just like the one on the dash. And can still use the dash button as well.
Originally Posted by KRB
(Post 3307858)
The switch in pictures 4 & 6 looks to me to be a vacuum machine switch.
You could let the latching relay operate a second relay like used for the air conditioning on our trucks. Mike |
Originally Posted by hfletcher
(Post 3307916)
?..Regarding the method described in the sticky I assumed since I don't have a TPS anymore, the computer could no longer control the overdrive shift. ... Could I have used the computer, as in the sticky, even though I don't have a TPS? ... Thanks
If your truck is 92/93 - splice one of the second gen lever OD switch wires into the OR/WH into the OD module & ground the other wire.
If your truck is a 91.5 - splice the lever's switch wires into the YL/DB and YL/BK on the OD module. The above will let you use either the dash mounted factory pushbutton or the second gen lever button as they will be wired into the same circuit. J.Fonder used the toggle switch wired to the OD solenoid as his '03 doesn't have the first gen OD module under the dash.
(Post 3307480)
