How do I remove the ignition key assembly?
Old Jul 4, 2008 | 08:33 AM
Trooperthorn's Avatar
I have a steering column out of a '92 or '93 ctd with no key. The steering is locked and the shifter is locked in park.
What are my options here?
1. Can I get a key made using the VIN #?
I am guessing not because you can see the vin from the outside and that would make stealing the vehicle pretty easy.
2. Can I get the lock assy out using my '95 key (which fits but won't turn)? If so how?
3 Should I take the whole column to the locksmith.
4. should I smack the guy in the wrecking yard who lost the key?
Help would be a lot of help, thanks.
Old Jul 4, 2008 | 08:49 AM
sooty's Avatar
key not
you can drill the tumbler or the set pin out, punch it carefully get auto parts store replacement
Old Jul 4, 2008 | 10:10 AM
Alwaysworking's Avatar
alwaysonDTR
pull the swich and the tumbler as one and re place both or figure out how to seperate them after they're off the colum. i think it should come off this way
Old Jul 4, 2008 | 11:46 AM
jckdann7's Avatar
find the light, go stright down and there is a little silver pin. push that with a screw driver i think.
Old Jul 4, 2008 | 03:15 PM
bob4x4's Avatar
They come apart differently depending on std col or tilt.Both designs you need to pull the steering wheel and lock plate to acess the release.with the std col you need to remove the upper housing as well.when you get the cylinder out it can be de coded and a new key made.
Bob
nrussell
Dec 4, 2009 09:29 PM
keithb7
Nov 30, 2008 07:25 AM
CStroked
Jul 7, 2005 10:55 AM
high country
Mar 4, 2005 08:35 PM
ET RAM
Jun 9, 2003 06:22 AM
