How to add 2nd Gen / 3rd Gen Towing mirrors to a 1st Gen CTD
Old May 14, 2007 | 10:13 PM
BRUISER's Avatar
This is a how to write up from my reference post:
https://www.dieseltruckresource.com/...d.php?t=150798
First I took the new mirrors out of the box and used some cardboard to make a template, which I could then transfer to Metal later.
The mirrors also came with a metal reinforcement plate so I used that to help locate the holes in my template.
Next it was time to start taking the old stuff off and get started.
So I first took out the small wing window, it is held on with 2 screws
I then took the old Mirror off.. There is a screw on the bottom of the chrome plate
Once you get the plate off you can then use a 10mm socket to get the mirror off.
Old May 14, 2007 | 10:14 PM
BRUISER's Avatar
Now back to making the steel plate.
I used the cardboard and transferred the design onto some 1/8” steel plate
the problem that I found was I made the 1st steel plate is was a little to small so I had to cut another piece of steel and remake the steel template
When I held the steel plate up to the window area I found that it was a little curved and so was the mirror plastic, so I used some Steel hammers to bend the steel top the correct shape..
Yes it is nice to have good tools
Old May 14, 2007 | 10:16 PM
BRUISER's Avatar
Once I had the plate shaped I took a air grinder and took the paint off the door so I could weld to clean steel..
Oh and good welding clothes help 
After everything was fitting correct I held the plate in place and welded it to the door..
The last part is to take the old mirror mounts off, and weld the holes up
After everything was welded up I took some Bondo and put it on the edge where the weld is, that is the only part I still have to go back and sand down..
I will get all finished pics later this week or this weekend.
Here is one of the drivers side
Hope this helps others that may be considering taking the plung to get better mirrors for towing.
Old May 29, 2007 | 08:40 AM
BRUISER's Avatar
Well the Mirrors worked great..
I could see the entire road and everything I was pulling..
One of the best mods I have done for towing..
click pic to see larger version
Old May 29, 2007 | 10:02 AM
whereswaldo250's Avatar
Those look sooo sweet, makes me want to do that. It does look a little intimidating. Great job Bruiser
Old May 31, 2007 | 10:51 AM
BRUISER's Avatar
Thanks..
I will state that once you go this direction it will be a pain to go back..
I will try to get some better full front shot this week
Old Nov 5, 2008 | 03:21 PM
BRUISER's Avatar
Well I know a lot of folks will hate me for doing this next mod.. but for me Good mirrors and visibilty when towing is worth it.
so yes I welded on my new style dodge mirrors.
Here is my old 1st Gen with the mirrors on it.. you can see they tilt up some..
so this time I took more time and made a new mount so they sit level, plus we braced then with some bends in steel so they woul dnot shack when driving down highway.. and so far at 70mph no shaking
ok on to the pics:
they are only primer for now but will be painted to match rest of truck once i paint the rest of truck..
Passenger side
Drivers Side
Old Nov 5, 2008 | 03:22 PM
BRUISER's Avatar
yes windows still open
pic showing inside
Old Feb 2, 2015 | 01:01 AM
rudie59's Avatar
Mirror mounts
Wondering if it's possible to get u to make a set of mirror mounts for my first gen.
Old Feb 2, 2015 | 10:01 AM
j_martin's Avatar
Perchance we could get a drawing with dimensions. This is a mod I'd like to do soon.
Old Feb 2, 2015 | 10:53 AM
rudie59's Avatar
Hoping bruiser will respond to thread comment L Martin otherwise if u stumble apon a way to do it or mount by chance could u let's know would be lend a helping hand I live right down in ham lake and see that ur from isanti.
Old Feb 2, 2015 | 11:25 AM
bobva's Avatar
I wouldn't my breath . bruiser hasn't posted in years.
Marine
Apr 30, 2008 06:34 PM
LawDodge
13
Jun 6, 2007 12:02 PM
casper_cobra
Apr 14, 2006 11:32 AM
BigDodge1
Jun 25, 2005 09:57 PM
ARAcummins
Feb 11, 2003 08:41 PM
