Here's a video of my truck running the most rpm it ever will.
From: A 5th dimension, beyond that which is known to man.
Awesome man... that right there makes my nerves settle about running mine the way i did before. 4000 is some serious rpm for stock springs. If you ever have a problem and need more stock springs ill give you mine to keep your truck running.
I hoped youd post David. I thought 3800 was a safe number too. That's where i thought i was (appx.) until i got home and did the math... Its not like it made any power up there anyway, just noise and MPH.
Like i said, im not looking to do it again. I just want people to reassure me that i didnt do anything too bad. I see the p-pump guys rev that high with the same stuff but im not as crazy as they are.
Oh yeah, Thanks for the write up on valve springs... i did everything exactly like you had written and it worked better than i even imagined. In like 4 hours i had it done, start to finish. It was an easy job, the only learning process was on the 1st valve and after that it was cake.
The dyno says there's over 400hp to the ground, but the torque is way down from it's peak. I made a few passes at the track with manually shifting (getting up in the rpms) and saw no advantage with the ET. With that, I let the trans shift automatically.Where a truck floats it's valves vary. Boost has an impact for example. 50psig is just that. 50 pounds per square inch of pressure on the back of the intake valve.
I'm glad the How-To proved helpful.
I hope my low boost will keep things settled. I am running 1/4" of pump timing advanced and the timing spacer so i can only hit 38psi of boost. I think i would be more like 42-45 psi if i was running stock timing.
zek405
25
May 18, 2012 07:25 PM
Valv
17
Apr 7, 2009 01:14 PM
fishin fever
Feb 22, 2004 08:32 PM
