Help with my new Radiator
Hello everyone, I need help. I'm about to put my new radiator in the truck. My question is. How do I get ALL of the old coolant out of the engine block? I drained the old radiator, and pulled off both hoses. Is there any old coolant still in the block?
I changing all the hoses, rad, and the thermostat. Thanks, for your help. Tony |
Originally Posted by TJE
(Post 1688348)
I like the CAT certified orange premix from walmat (Global something?) |
Originally Posted by mhuppertz
(Post 1688355)
You don't. Just do your thing with the new parts and fill it with the good premix stuff. The little that is still in your block will be very diluted.
Hello again everyone, I did some checking, but still don't know for sure so I'll ask the question differently. Is ALL antifreeze, compatible? Or will ANY antifreeze work? I was told that the orange colored AF will not mix with the other AF. That when mixed it will turn to gell. Is this correct?
Thanks, Tony |
You could pull all the coolant lines loose and pull the thermostat, then back flush everything with the garden hose, including the heater core. Not only will you get out almost all the old stuff but a little rust and junk too.
Originally Posted by Boatnik
(Post 1688856)
Later, Tony |
I've done alot of rad swap and or repairs to were I had to refill the whole system and I never really woried about the old stuff unless the inside of the rad showed alot of corrosion or liquid was gummy while draining. Besides most of the old fluid is already drained, if the fins of your rad look corroded it might be in your best interest to take it to the local rad shop and have them run it through there magic cleaning tank and check it for any current or potential leaks, it will help it run cooler. As far as I know Dexcool was only used in GM's and yes it does gel if mixed with normal AF, my mother in-law and sister in-law both did it in there GM's and unfortuatly for me I had to fix it (I wish I would have taken wood shop instead of auto mechanics in tech [duhhh]).
