Headlight Switch New and still problems
Hello everyone I didn't see this when I searched, so here goes. I replaced the switch and still have the same problem.....I have headlights but no dash, or taillights! What gives?
I can wiggle the on/off **** and dash and taillights will come on as long as I'm holding the ****, as soon as I let go they go off again. This was the case with the old switch as well.
Can someone help me with this?
Thanks, Tony
Thanks, Tony
did you replace the connector? Because I would bet it is the connector...Should replace both at the same time because you never know what it melted on the connector if the switch gets too hot.
update
I just fininshed wiring in the NEW headlight switch connector....(BWD brand)
and still have the same problem!
I can wiggle the on/off **** and the dash and taillights come on......aggravating to say the least.
Another thing are the headlights wired into the grid heaters?
If anyone has anything else to offer please do.
Thanks, Tony
I can wiggle the on/off **** and the dash and taillights come on......aggravating to say the least.Another thing are the headlights wired into the grid heaters?
Thanks, Tony
Also you may want to try removing the headlight switch lever and re-inserting it, to ensure it is centered and fully inserted.
No they arent, the dimming of lights while the heater grids are cycling is simply the power draw on the electrical system and is normal.
Well I got it back to where I started. The new switch is trash! When I put the stem in it, the stem is way loose....plum sloppy, so I'm taking it back. I'll keep the new connector as it has bigger gauge wires than the original.
I'll keep you all posted.
Thanks, Tony
Thanks, Tony
my experiance with the BWD brand from oriellys has been terrible. was replacing a inner fender mounted selinoid on my 73 ford one time, and when I was just about finished my pickup started and took off all by itself. pulled an old rusty one off a parts truck and it still works fine. They don't make the floor mounted dimmers worth a darn either.
