head studs
Old Oct 21, 2008 | 09:57 PM
HARDTIMES's Avatar
head studs
how much boost can studs and a new gasket hold? no o-rings
Old Oct 21, 2008 | 11:40 PM
RuralCruiser007's Avatar
The easiest and most smart aleck response is until it lets go.
It depends on whether you use 14mm head studs rated at 200,000 psi or the full race set rated far higher. It also depends on the quality of head gasket used. Guys on here have used Fel-Pro head gaskets with good luck, and some have had issues with them. It is said to use a Cummins head gasket for the best. There are other aftermarket head gaskets out there Commit(sp?) is one that is most talked of for running higher pressures.
If you really want to guaranty higher boost pressures, then installing fire rings is the way to go.
One saying that keeps coming up is: "If you wanna play you are gonna pay!". The question is, do you want to pay a little now or a lot later?
Just my thoughts,
Glenn
12valvetom
Nov 27, 2009 11:37 PM
dieselboy59
Jan 30, 2009 03:57 PM
smokewagon
Aug 8, 2008 09:54 PM
MikeThomas
May 11, 2008 11:39 AM
jmccart
21
May 14, 2007 11:47 AM
