Head Studs
Old Sep 5, 2006 | 02:58 PM
Fergavs's Avatar
Head Studs
Looking for headstuds but ARP and BD only list 94-98 12v trucks for their head stud kits. Can these be used on a 1990 truck?
Old Sep 5, 2006 | 03:12 PM
goodtyms's Avatar
Yep, I just installed the ARPs on my '93. You'll likely need to grind the inside of the valve covers and slightly shorten the studs in order to prevent valve cover interference. My understanding is that the older blocks weren't tapped as deep/consistantly as newer ones.
Old Sep 5, 2006 | 03:13 PM
apwatson50's Avatar
99.9% sure yes
Most performance shops don't/won't acknowledge that there were any dodge cummins built before 94 so even though something will fit our older trucks they just have their head stuck up their *** that they can't include our fine trucks.
We just have to be smart enough to figure out what will fit and what is different. The basic block/head did not change until the head changed in 98.5 with the 24 valve and even then the block is basically the same.
Old Sep 7, 2006 | 10:35 AM
Underpsi's Avatar
Got Arps on my truck and they fit with grinding the valve covers,
This is with the non-ic 9mm head
Old Sep 8, 2006 | 09:42 AM
goodtyms's Avatar
Lucky you!
My understanding is that there's enough variation that you won't know until you try. My valve covers are chrome an it makes really evident that there's contact between the studs and V/Cs because you can see the V/Cs bow as you tighten down the V/C nuts. This can cause the V/C gaskets to leak because they aren't compressed as they should be.
12valvetom
Nov 27, 2009 11:37 PM
dieselboy59
Jan 30, 2009 03:57 PM
smokewagon
Aug 8, 2008 09:54 PM
MikeThomas
May 11, 2008 11:39 AM
jmccart
21
May 14, 2007 11:47 AM
