Guess that axle(1st gen axle upgrade)
Old May 12, 2009 | 09:24 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
Nah I learned my lesson drinkin and driving
Yeah I tryed quittin smokin again a while back but.........
Old May 12, 2009 | 10:42 PM
Thanks for the info.
I like to see out-of-the-box thinking that is obviously an improvement over stock.
Show us more.
Jeff says
"I don't like to think inside the box unless I got my .45, its dark in there"
Old May 31, 2009 | 01:13 PM
Heres a few more
Old May 31, 2009 | 01:20 PM
CaptainChrysler's Avatar
Looks sweet!
What is that mount on top of the punkin fer?
Is that a 1410 yoke? Can you get bigger ones for it?
Old May 31, 2009 | 01:43 PM
Originally Posted by CaptainChrysler
Looks sweet!
The mount on top is for another bar to tie into the hitch and yes thats a 1410 yoke I think it the biggest yoke you can get for the HO72
Old May 31, 2009 | 02:34 PM
BearKiller's Avatar
Now I see why Harbor Freight was out of jack-stands the other day.
What is the black steel gizmo with the red hitch-pins that, in the picture, looks like it is holding up the fuel-tank ??(I'm sure it's an optical illusion.)
Looking good.
Old May 31, 2009 | 02:37 PM
Weight bracket for the front.
Old Jun 3, 2009 | 11:02 PM
Couple more pics
Old Jun 4, 2009 | 08:03 AM
BRUISER's Avatar
where is your exhaust? or do you have stacks?
Old Jun 4, 2009 | 04:11 PM
Alwaysworking's Avatar
alwaysonDTR
that truck has a hood stack
Old Jun 4, 2009 | 10:51 PM
Mieser's Avatar
How does the wms width compare to the stock d70? Is the eaton any wider?
Old Jun 6, 2009 | 11:06 PM
The HO72 is an inch and a half wider at the wheel mounting surface, so physically it fit under a 1st gen very nicely
Old Jun 7, 2009 | 12:52 AM
gadget.35-06's Avatar
Cool part about the H series axles is that thrust shoe that keeps the ring gear from creeping away from the pinion, and the pinion being straddle-mounted. Good luck tryin' to break that once it's set up correctly!
Old Jun 7, 2009 | 09:28 AM
What gearing? Will he have to change the fronts to match the rear?
Clean install. You guys do nice work
Old Jun 7, 2009 | 09:07 PM
The gear in the rear is a 4.57, and yes we just dropped the front out friday night to do the gear change toss a powr loc in and upgrade to the D70 outers, hopefully gonna be goin back in monday night
Thanks for the compliments, Jeff has done most of the work I just come over to help with some of the heavy stuff and welding mounts and perches on
