Grid heaters cycling on a warm engine?
I turned on the ignition key and jumpered from the positive battery terminal to the Engine Start wire on the side of the solenoid. I was able to get sparks but no other action...
Yesterday I drove about 150 miles. The voltmeter jumped to the far left (not quite pegged) but it stayed there for about 45 minutes as opposed to cycling. Then it returned to normal for a few minutes, jumped left for another 45 minutes, and then returned to normal for the rest of the day. It seems John Martin is correct in that this isn't a grid heater problem.
There is VERY large red cable along with a much smaller black wire, both going to the solenoid on the side of the starter. In reading the sticky on rebuilding the starter, the small black wire is called the "Engine Start" wire.
Guys, I'm woefully ignorant -- I'll need some help identifying the "FSS."
TIA
TIA
If you jumped to the small solenoid wire and nothing happened, then starter is toast, you can try smacking it a couple of times to see if it starts, but that is only a temporary fix.
I tried jumping to the small solenoid wire with a relatively small wire; I'll get a set of jumper cables and try jumping with those.
Try giving the starter body a few smacks while you are under there.
. So my starter died in the midst of my trying to figure out my charging problem. And of course the truck is outdoors in a steady rain. These First Gens look great but they do in fact have dependability issues.
Thanks for all the help; I will revert if/when I identify the charging gremlin.
Thanks so much. Have now tried heavy duty jumper cables from positive battery terminal to small wire on solenoid, as well as three rounds of smacking the starter/solenoid with a small ball peen hammer. All to no avail
It appears that your starter died. Starting with a low battery is very hard on starters, so no surprise.
If you get it running, and a test light or voltmeter in hand, call me and I'll walk you through charging diagnostics.
Okay, I'll concede I'm guilty on this point. But in my defense, it is tough to diagnose a problem that manifests itself for only two minutes at a time at 70mph.
Update:
I phoned the local AutoZone on Sunday night during the Super Bowl and they had me a starter (remanufactured in China) by 9am on Monday for about $100. After purchasing the new starter, on a whim, I turned the ignition key and the truck roared to life. (This was a Godsend -- it enabled me to get the truck into a carport out of the wind and onto dry concrete.) I replaced the starter but decided to keep my old starter (and forgo the $31 core rebate) because it is the OEM NipponDenso and I already have the "Larry B's" rebuild kit to put in it.
The reman. starter works fine and this morning I drove the 120 miles back home -- now the charging issues seem to have disappeared
. Could my battery discharge problem have been something awry in the starter and/or solenoid? If so, when I open up the starter what do I look for to satisfy myself that my charging problem was not coming from elsewhere in the truck?
Thanks again to all to have chimed in; this forum is a lifesaver.
Update:
. Could my battery discharge problem have been something awry in the starter and/or solenoid? If so, when I open up the starter what do I look for to satisfy myself that my charging problem was not coming from elsewhere in the truck?Thanks again to all to have chimed in; this forum is a lifesaver.
Update:
Update:
You were messing with the wiring when the starter failed. You might have tugged on something that was intermittent. Chief suspect would be the heavy connector between the battery and the splice where the duck foot and the generator power cable come together.
Best bet, though, is don't just pull and tug on things if the bug comes back. We should set a trap to see if the alternator is fielding when it's failing, which would give us a definite route to follow to the problem.
Katmandu
Nov 8, 2006 10:23 AM
silverbullet02
Oct 1, 2005 11:30 PM
