fuel sending unit hook up
1 Attachment(s)
so im replacing my fuel sending unit, but I feel like I'm missing some things. I know where the fuel return/supply lines go but I'm not sure about what connects to the to the other 2 fittings I have circled in the picture. I feel stupid for forgetting but I took the old unit out 6 days ago before a 75 hour work week. Any help would be greatly appreciated.
1st one circled at 10 o' clock position is rollover/vent. Dont break it! Its irreplaceable as no longer made. Put a piece of 3/16 or 1/4 inch hose over it to keep the mud daubers out.
2.d one is nothing. Probe with a screwdriver and you will see it dead ends. Just for looks. |
https://cimg1.ibsrv.net/gimg/www.die...07104521cb.jpg
Originally Posted by jerseybud
(Post 3331647)
Is this sender on your 1991 in your signature?
Where did you get a replacement and how much did it cost you? Mine will be on empty and $30 dumps it on the ground. Never really know how much is in the tank. Thanks. |
Originally Posted by Jim Lane
(Post 3331654)
Where did you get a replacement and how much did it cost you? Mine will be on empty and $30 dumps it on the ground. Never really know how much is in the tank. Thanks. Sucks that parts for these are disappearing. I hate forking out the $$ for something that's gonna sit on my shelf for the one day when I'll need it. It can get expensive being a parts hoarder, but I guess if we're gonna be keeping these trucks, that's what needs to be done. My wife, for sure, doesn't understand, lol, the hoarding of parts "for one day" |
(Post 3331654)
Stupid Chrysler put a plastic sleeve (black in your pic) inside the fittings that prevents you from getting to the spring inside that you would use one of those fuel disconnect tools to get it off. I have removed them with needle nose pliers before and then replaced the fitting with one from napa, advance, etc. The coated with fluid film so it doesnt rust inside where the clip is.
Using a dremel cutoff wheel only at the widest part to "clamshell" it to pull the spring out is ok too, but if you mess the o ring sealing surface up, its the same as breaking it with a sledghammer- both are ruined Not too hard to make a diesel unit out of a gasser unit by taking the pump out and making a siphon tube. |
