Fuel line from tank fitting
'93 Club Cab, D250. PO cut the plastic fuel line from the tank to add a Parker Racor prefilter set up. I've by passed that filter setup for now since it was before the LP and probably reduced flow (2 micron filter was installed). Anyway, the original line was cut and a rubber fuel line hose clamped on to the tube. Getting some air into the system from this hack connecting and want to do something better. Is there some type of fitting I can retrofit? I came across these couplers, thinking one side into plastic line, the existing rubber hose connected to other? Open to ideas. The OEM nylon/plastic lines are 3/8" correct?
Brad5502
Jun 3, 2009 11:03 PM
getblown5.9
Sep 29, 2005 08:29 AM
