Fuel economy issues
Fuel economy issues
So I posted on here several months ago about head gasket and oil cooler replacement. When I put it all back together, I obviously had to adjust the valves which was the first time I ever did so. My fuel mileage has seemed to be 3 to 4 miles per gallon less than before the work. Is it possible that I did not adjust them properly? Anybody have any thoughts ?
what did you set the valves at?
Did you rotate the engine back to TDC on #1 cylinder and recheck your valves after your first adjustment? Sometimes rotating the engine another 360 degrees allows the valves to seat and could change your adjustment. I believe that the intake gap should be .010" and exhaust should be set to .020".
One reason I love my 1st gen...
Fuel mileage..
Your fuel mileage can't be as bad as these guys in the 4th gen group..
https://www.dieseltruckresource.com/...0-t301083.html
7 mpg average ??????
Thanks, but I'll stick with my old truck.....
Fuel mileage..
I was between 18 or 19 now more like 15 or 16. It doesn't seem like that much but it bothers me. I think it's time to look into some minor modifications. It still has a muffler so I think I will straight pipe it as I think I am the only guy with a cummins that hasn't done so yet and look at the valves again.
Blessed
Mar 1, 2013 04:38 PM
bc3
Dec 1, 2007 10:19 PM
Hummin Cummins
Jan 27, 2003 08:31 PM
ridofpwrstroke
Nov 1, 2002 07:10 AM
