Fuel Additives?
Hey Everyone!
Before I ask my question, thanks to a bunch of you who helped me out over the years. After marriage, the old cummins fell by the wayside. I didn't really need it, nor did I have the parking for it. Well that has changed! Luckily, I have hung onto "Big Red" and will be using it more frequently for work and a small business I am starting this year. [guitar] What Fuel Additives do you all recommend? I'm not a fan of ULSD. If I ever thought I needed a little more lube I would grab a quart of ATF, or about a quart of veggie oil. As a sidenote, the veggie oil seemed to really quieten the truck down. Do any of you run Stanadayne? I've heard good things about their formulas at the local diesel shop I was working at in 2016. Thanks! |
i have herd good things about the stanadyne fuel additives in the duramax world having a very noticeable mileage difference, as for the first gens i have not herd of anything yet, i might just have to try it in mine as i do drive 50km a day to get to work and back.
stanadyne is cummins and bosch approved, so there is that.
biodiesel is the best if you can find stations that sell it. we have a chain of stations here now that that's all they offer for diesel. i try to fill there as often as possible. some other good additives are optilube XPD and Soy Shield. |
Standadyne, FPPF, OptiLube, and Power Service.
-Kris |
Biodiesel? Other than the praises that Willie sings about it at his station south of Dallas, this is the first "fill every chance" endorsement I have seen. Why biodiesel? I get putting in lube additives, but full tank, bio, half and half, or other ratio?
Not doubting, I just don't know why. |
Originally Posted by bmouser
(Post 3319362)
Personally, I'd love to run bio diesel, its kind of hard to find in Southwest Virginia though. Sidenote: what is it with guys suggesting to run 2 cycle? I understand its lubricating properties, I worked in landscaping for six years. What makes it better than say a quart of ATF?
Originally Posted by TheMrAMack
(Post 3319383)
I believe the theory is that 2 Stroke oil is designed to be burned where as ATF is not.
It is also designed to be a lubricant in the 2 stroke motors so there is obviously a lubrication component. I've used the cheap Walmart 2 stroke oil and regular non winter PowerService in mine with out issue, actually filtered engine oil and put that in too. |
Good stuff, Ill keep what you all mentioned in mind.
Thanks! |
I don't even know if bio-diesel is available up here in Canada ... I'm sure it is but I've never noticed.
Anyways I'm all for "cleaning " the fuel system anyway I can do if I can find it I may give it a couple tanks full and see what the filter looks like ... any troubles with it gelling up or just the usual splash of howles or power service and good to go?? Thanks again.. SD |
Its available here, just hard to find.
In the 12 or so years the truck has been in the family, I don't remember it ever gelling up. We always ran diesel 911 during the winter months. Thanks! |
Can't answer the gelling biodiesel question but I asssume it would gel just as #2 would. I just run winter blend, no cold weather additive, when I'm up north and no issues.
Ultra Low Sulfur Diesel Fuel Technology Pamphlet from Cummins
If you haven't already seen this, you might find it interesting. |
Originally Posted by Alec
(Post 3319426)
If you haven't already seen this, you might find it interesting. Thanks for posting that. |
