front seal on the IP question
Old Oct 17, 2011 | 12:20 AM
Rick 12v CTD's Avatar
I have retained my front seal so it won't push out when running higher inlet pressure.
Anyone know at what pressure the seal itself will fail at or begin to leak? I wanna run a second gen lift pump but don't want the seal to fail or leak diesel into my timing case and contaminate my oil...
Old Oct 17, 2011 | 01:35 AM
Jklawinsky's Avatar
With loctite, you could push around 30psi. Maybe you could higher, maybe someone else that has pushed it further will chime in.
Old Oct 17, 2011 | 11:52 AM
I'm not using loctite. I retained the front seal with 4 little tiny (m4 I believe) large head hex head screws that overlap on the seal. Just got a machine shop to drill and tap the case for the screws. The screws are large heads but don't protrude out far from the pump. I got the idea from JQ a little while ago.
I used blue loctite to keep them from coming loose.
I'm just curious to know what the true failure pressure is on the seal itself. If anyone even knows.
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Mar 6, 2011 01:09 AM
92smokin blacky
Jan 4, 2011 12:43 AM
RTillery
Feb 7, 2009 08:46 AM
dieseljerk
Jul 8, 2004 07:23 AM
