Front leaf spring hitting frame?
Old Dec 30, 2010 | 09:40 AM
93 high hopes's Avatar
Has anybody had this happen? It is the rear mount just below the drivers feet. Quite an annoying sound
Old Dec 30, 2010 | 10:19 AM
simplysmn's Avatar
Yep sound's like it's time for new spring's or maybe shock's
Old Dec 30, 2010 | 01:20 PM
PapeCAT's Avatar
Nah the springs should never hit. Doesn't matter how bad your arch is or shocks.
The problem is because you have a blown out or worn out leaf spring BUSHING. You can press them out and press in or drive in new ones in Poly or Rubber flavors.
Old Dec 30, 2010 | 02:27 PM
Bushings are what I thought, any part #'s?
Old Dec 30, 2010 | 04:39 PM
TIMMY22's Avatar
Those are real fun! Heat the old ones up till they lite up on fire, then just push the bushing out w/ the molten rubber burning and dripping.
You're going to need a big press for the new ones. It takes some serious force to push them in.
Old Dec 30, 2010 | 08:04 PM
How does one press in rubber??
Old Dec 30, 2010 | 08:53 PM
I found these on ebay, does anybody know if these are the right ones?
http://cgi.ebay.com/ebaymotors/ws/eB...m=390273877715
Old Dec 30, 2010 | 09:46 PM
big_country_001's Avatar
I changed mine and they were so bad the old ones just feel out and the new ones went right back in no prob
Old Dec 31, 2010 | 02:50 PM
Trooperthorn's Avatar
Poly bushings usually press in pretty easy. The rubber on fire method is the best way I have found to get the old ones out.
Old Dec 31, 2010 | 04:15 PM
schamran's Avatar
NOPE! They don't have the lip on the edges like that. They are one piece, and they are different sizes for front and rear. They have a metal sleeve inside and around the rubber. Local Auto Parts Store will have a listing for them. I have no experience with poly bushings, but start the rubber ones on fire to get them out. I actually used a hole saw that fit between the metal sleeves and drilled them out. If the outer sleeve is stuck, cut a slit in it with a hack saw or sawzall and it will curl up and slide right out.
Old Dec 31, 2010 | 08:37 PM
This sounds like fun, but its got to be easier to deal with than the BUMP BUMP BUMP sounds
Napa wants like 8 bucks for each bushing, is this high?
Old Jan 21, 2011 | 10:38 PM
So after removing the stock shackle, I found out that the bushing is fine.
The springs have lost all arch and are reaching the frame, so for the time being, until I get the springs re-built, I just bought some 6" shackles, worked like a charm and raised the front end where it should be.
But...after I got the new shackles in the noise was still there! Turns out the shock mount had worked loose, 2 minute fix. Oh well
Old Jan 21, 2011 | 11:02 PM
TLRMAN's Avatar
I just read this today and had a lower shock mount do the same thing. Bugged me for weeks till I got off my but and checked it...
Old Jan 22, 2011 | 11:25 AM
oilcan64's Avatar
you can get rubber ones from rockauto.com i think it cost something like 60 dollars for all four bushings when i did mine
Old Jan 22, 2011 | 12:05 PM
cougar's Avatar
Don't forget to do the shackle bushings on the frame. You can get them from the dealer cheep.
