front hubs loose
Old Sep 18, 2010 | 12:12 AM
countryboy_660's Avatar
front hubs loose
my front driver side hub is wiggley. all the alen heads are tight but it still rattles. any ideas before i go ripping the front end apart?
Old Sep 18, 2010 | 09:22 AM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
the lockout or the hub? my hub assembly was loose too because i didnt properly torque the bearing retaining nut when i assembled everything.
Old Sep 18, 2010 | 10:36 AM
maybe368's Avatar
I believe that the looseness is normal, it all has to float free for easy engagement. I don't know why it would rattle though. Mark
Old Sep 18, 2010 | 10:45 AM
Wettstein's Avatar
Check the kin pins. on the top king pin there isn't a bearing it is just a plastic cone and they get worn out. after 400k miles mine where prity bad.
91oldranchtruck
Jan 31, 2011 09:45 AM
Leaky Gasket
Aug 14, 2008 07:17 AM
keffa11
Mar 10, 2004 11:56 PM
