First Gen front axle swap for better brakes.
I got them at Brake Performance try the link below. BTW they are sloted and dimpled.
www.brakeperformance.com
Bob
Bob
I have the dana 80, but still drum brakes. I talked to a place yesterday about the parts for a disc conversion on the rear. The price is ok, but the benefits are slight. I want real brakes, not just a little bit better brakes. I should hear back today about the parts to change to the dual piston 14.5 setup. They offer it in a complete package(new drop in front axle assy) but it's more than I want to spend($6200+shipping). Hoping their kit that just replaces the outer components will fit.
I have done the GM wheel cylinders and 3" shoes, it makes a good bit of improvement. Seems to need adjustment more often though. I think because of the the larger wheel cylinder but the same master cylinder, it requires more movement to get the same travel of the wheel cylinder.
I would think two calipers are going to overheat the rotor that much more?
Thanks for the link on the rotors.
Bob
Bob
Bob
Bob
put a hydro boost and master off a 2nd gen if you have not already. my truck stops scary good with a master/hydroboost off an 01. It moves way to much fluid for single piston fronts and 1ton dodge rear wheel cyls. I mean you can put a pringle between the pedal and your foot and not crush it and lock up all 4 wheels.
well maybe not that crazy but it stops scary good unloaded
Amen to that, i just treat the adjuster as a wear part and replace every brake job. going into that full float every time for a brake issue gets old. On that note how common was the full float 60 on these trucks?
