Engine code 46???? Pulsing Lights???
Old Oct 18, 2007 | 12:40 AM
MikeThomas's Avatar
So could the check engine code 46 (charging voltage too high) be the source of my dreaded pulsing lights? I hear the pulsing light can be a diode in the alternator....can that be the cause of my "overcharging".
Old Oct 18, 2007 | 01:23 PM
MikeThomas's Avatar
Ahem.......?
Old Oct 18, 2007 | 02:05 PM
whereswaldo250's Avatar
Hey Mike I wish I could help you I would also like to know
Old Oct 18, 2007 | 06:55 PM
I would throw an alternator at it.
Old Oct 18, 2007 | 09:46 PM
TJE's Avatar
TJE
I had the same problem on my 91.5, for about three years to be exact. I had the alt. tested, it was good. I changed the VR, and still I had pulsating head lights. I even ran a ground from the alt. to the frame, and still the head lights had a pulse to them. I finally took it to an electrical shop. in about ten minutes he found the problem. A bad ground, the battery was not getting a good ground. I had even replaced both terminals, with gold plated terminals.
I hope this info might help you. Tony
sleepy
Nov 3, 2010 04:17 AM
sleepy
Nov 1, 2010 10:39 PM
Walt L
Oct 26, 2010 10:58 PM
92cummisw350le
Oct 16, 2007 10:47 PM
