Dumb Question...
Old May 20, 2007 | 09:46 AM
Biggator's Avatar
Dumb Question...
Hey Guys, here is a question for you.
I recently degreased/pressure washed my engine, the water in fuel light came on afterwards. I know the sensor on the fuel filter(new) will show water in fuel if it gets wet so I wasn't concerned. Well it stayed on for a few days so I depressed the valve on the fuel filter and got what looked like a small amount of water. I opened it all the way and got what looked and smelled like pure diesel. It would drain for as long as I opened the valve.
Are there two stages to the drain, or is there a problem?
Thanks!
Old May 20, 2007 | 10:44 AM
BearKiller's Avatar
You probably have moisture trapped in the plug for the water-in-fuel light, shorting across, fooling it into thinking there is water in the filter.
Old May 20, 2007 | 11:24 AM
Biggator's Avatar
Yeah, that's what I figured. Do you know anything about the drain on the filter? Will it only drain water or will diesel also come out?
Thanks!
Old May 20, 2007 | 03:34 PM
ixx's Avatar
ixx
it has been my experience that it will drain anything out of the filter, water diesel, liquid midgets or anything that will fit
Old May 20, 2007 | 04:02 PM
Boatnik's Avatar
Whatever is in the filter bowl will drain out. This a neat feature when you change the filter. Place a catch container under the drain hose and open the drain and vent. When the filter is empty the mess is less.
Old May 20, 2007 | 04:50 PM
Biggator's Avatar
That make sense, thanks for the info!
Old May 20, 2007 | 05:59 PM
BearKiller's Avatar
Before getting things wet, again, pull the plug apart, smear in a glob of Vaseline, and re-plug.
The Vaseline is about the best water repellent available.
calvin
Jan 4, 2003 10:41 AM
TPilaske
Jan 1, 2003 12:57 PM
Push Rod
Dec 31, 2002 10:46 AM
wheels
Dec 22, 2002 10:49 PM
bigbaddiesel
Dec 7, 2002 07:40 PM
