dealing with ice on widshield
In the mornings I am fine since I park inside overnight. Once I park at work though and the engine cools down what is the best way to get it cleared up again.
Takes forever idling for the engine to warm up when it is in the lower twenties outside and sleeting.
Chemical deicers work well?
Just wondering what others have found.
Personally, I have also found that methyl alcohol works great, I add some to my windshield washer fluid, but also carry a spray bottle of the stuff pure. Dissolves any ice from anything. I do avoid the paint though, just as a precaution.
Mishkaya
Mishkaya
A great ice scraper works the best for me. Rain X has some stuff now that helps keep the ice off the windshield and also makes it repel water rather well. But still it will freeze when it gets down there (-5).
I used to have that problem when I lived in Michigan and never liked it much. I took care of that when I moved to Southwestern New Mexico. Now if it gets a little frosty in the AM, I just use a scraper and in 2 min I'm done. I still complain about that
Yep, here in ks we get the worst of both worlds
get the heat and humidity of the southeast in the middle of summer. Then the cold of the north in the middle of winter.
The weather is perfect about 4wks out of the year.
Originally posted by Haulin_in_Dixie
Ice?? Well its 72 outside, move south
I probably should put some sun screen on today to work outside on the truck.
Den
Originally posted by andyr354
Is that denatured alcohol you are reffering to?
Mishkaya
Originally posted by Den
That's the stuff you put in drinks, HD, when yer out workin on the truck
Den
Den
