D70 brakes?
D70 brakes?
After reading the stickie I know I need a special socket for removing the nut to get the drum off, my question is will that same socket work on the front axle and how about my 14 bolt on my chev. Thanks.
Thanks for the replies, I bought the socket at checker for like 16.00. The previous owner used a screw driver though. It definetly aint the same socket as the front and not sure on the 14 bolt yet but hopefully I'll get lucky.
The truck failed saftey for a 0 reading on the rear brakes so I pulled the driverside and they looked ok but a little oily, then the other side showed why, the bearing just fell out when I removed the hub and the self adjusting cable was broke and missing parts plus some of the other springss were broke. Also someone has spliced a new axle tube in between the 2 bearings, they did a good job though but didn't put it back togeather very well. Brakes work great now.
fordsux8269
23
Jan 30, 2006 07:18 PM
ddestruel
Jul 2, 2005 11:13 AM
