Copper washer for injector tip.
Old Jul 4, 2018 | 07:33 PM
B Miller's Avatar
The Cummins is a 1990 engine with a 1991.5-1993 head.
When I took the 7mm injectors out, I found no copper washer to set the spray position in relation to the piston.
Would this be normal when using a later head with 7mm instead of the 9mm injectors?
Old Jul 6, 2018 | 10:41 AM
cougar's Avatar
There is supposed to be a washer. It may be stuck in the bottom of the hole. As far as washer thickness, all aftermarket injectors use the thinnest washer because they are slightly shorter than the stock ones.
AggieJustin
Jun 27, 2009 12:55 PM
dieselrob
Jul 7, 2006 04:12 PM
turbo6justin
Apr 22, 2006 07:17 PM
cjones42
0
Mar 16, 2006 07:35 AM
